1200 Enduro Mts Enduro 2016 Rear Spring Upgrade.
Discussion in 'Multistrada' started by MJW61, Jan 25, 2017.
  1. Hi troops. Any leads on rear spring option upgrades (Sachs) for the MTS Enduro?
    Thanks in advance.
  2. Its electronic, so why would you? I'm pretty sure you can only change the preload on the front forks using the right-hand dial on the yoke. And the rear is electronic so you go into the settings before firing the bike up. What seems to be the issue that has sparked this idea MJM61? You just fancy over blinging the bike with the extremely expensive kit available?? What style of riding are you doing; two up, solo & luggage et cetra.
  3. No bling. The spring is still too soft.
    Yes I'm quite aware of the electronic adjustment.
  4. I find the suspension too soft on my Enduro as well. After 10 years and 100,000 miles on KTMs, its a bit of a shock - no pun intended!!
    Using the dash controls I have stiffened it up as much as I can and will have to wait and see if that's improved the ride.
  5. A few skyhook riders have changed their rear springs. May be in the link Andy has posted, but the thinking is the bike has to be in the right working range to work as well as it can. :)
  6. Thanks one and all for the advice. Really appreciated.
    My enquiry is for a mate who is unfamiliar with the site. All info passed on.
  7. visit: propilotsuspension.com
    The answer to all your questions
    Br Gert
