1260 Multi 1260 Air Filter Options...
Discussion in 'Multistrada' started by MaxDec10, Jan 20, 2025 at 11:48 AM.
  1. Personally I wouldn't bother. They may flow more air but also they're not as efficient in preventing small particles as the OEM filter. Debateable as to there being a peformance/bhp boost with a K&N, you will probably get an increase in induction noise though. The costs and time of washing and re-oiling in K&N specific oil negate the theoretical price advantage and convenience of just swapping the OEM filter as well.
  2. Thanks Bumkin. As you say, I'm not chasing a couple of extra bhp so will likely go with OEM.
  3. Agree with @Bumpkin, stick to OEM. Given the location and PITA to clean K&N, it's not going to be worth it.
    Plus, if you're not tracking the bike, you'll want the paper filter as the K&N jobbies will left through fine particulars if not oiled and maintained.
  4. I've had a Pipercross filter in my 1200 for 4 years and 30000 miles, just remove, clean and re-oil every Desmo. The oil is still visible from the previous clean, inside the airbox is spotless so I have no issue using them.
  5. Put a K&N in mine despite a few people telling me it would gum up my MAF sensors or something, I dunno, no issues yet (though it doesn't come out very often admittedly).
    Isn't it good for ludicrous mileage before it needs cleaning, can't remember ...
  6. I looked, 50,000 miles, normal road conditions supposedly. That'll take me a LONG time.
  7. as above I'd stick with standard pal, i've used k&n over the years on other bikes and they don't filter as well as standard.
    unless your chasing power then its not worth it.
  8. I agree. Arguably the filter won't do much, if anything, for power on it's own. You'll need to be doing other tuning work as well to make appreciable gains.
