1200 DVT Multi Height
Discussion in 'Multistrada' started by did, Mar 19, 2018.
  1. Hi all
    Might be picking Multistrada DVT up at the weekend and would need to get it in my Vito dualiner. Could somebody tell me what the heighest point measures from the ground when the screen and mirrors are removed please?
    Thanks
  2. My 1260 is 50’ which will just clear the screen adjuster in its lowest position. This will clear the hand guards and brake fluid reservoirs. (Screen and mirrors removed of course) btw that’s in urban mode which is lowest suspension setting on the rear
  3. Not 100% but its about 1100mm from the floor to the screen mount part. The manual only shows it with the screen and mirrors on and from the ground to the top of the standard screen in the lowest position is 1350mm
