Sorry in advance as I'm sure this will have been asked many times. Multistrada 1200dvt misfire issue , I'm running a healtech servo eliminator and the servo including butterfly valve is removed, been fine for the past year but now developed a misfire when under load that has progressively got worse. Having done some research and looked at various threads I'm thinking HT leads so I'm going to replace them. Question is original parts or aftermarket? Finding aftermarket difficult to source, any ideas/suggestions would be appreciated.
I would use OEM, they have been upgraded to prevent the deterioration issues that plagues the first DVT's. I had mine changed and they are not OTT expensive. On mine it was the rear lower lead that was causing the issue. It's usually that one particularly, but also very rarely the upper ones anyway. Swap the lowers first and see if the issue goes. I would expect it to
I had to replace the front one. Just took a guess at it being the front one as it’s more exposed to the elements. I have found the Ducati dealer parts diagrams to be very good. There are a few about that you can just order online.
Can recommend Moto Rapido in Winchester for parts, just WhatsApp the parts dept, v quick response and posting
