1260 Multistrada 1260 Redline
Discussion in 'Multistrada' started by DarR, Jun 6, 2019.
  1. Just noticed that no redline is indicated on the tachometer.
    Normal or not?
  2. doesn't the dash change colour as fit gets up to the top of the revs, so it becomes a red led band?
  3. Numbers turn red at redline
  4. Ok thanks.. I'm still on run-in riding just having had my first service. I haven't rev'd it to those rpm's.
    I'll check that out.
    #4 DarR, Jun 6, 2019
  5. You also get flashing red lights on the top of the dash.
  6. And it hits the limiter really quickly once you hit amber! It’s amazing really how quickly it spins up given what a big, limy motor it is as standard
  7. The Multistrada is different from both the Panigale and the Monster which displays the redline while idling.
    Thanks for the heads-up guys.
  8. Slightly off topic but on a similar note, my mate has just bought a GS 1250 and he showed me the red line on the TFT screen is at a different rpm when the engine is cold and increases as the engine gets warmer.
  9. Apparently, so does the MTS1260
