hi all. i have a question. Can 2012 Ducati install at multistrada 2013 ? my original multistrada front wheel rim is broken, so i search in ebay and i found this rim look like original multistrada front wheel rim. thanks for advice ... (picture from Ebay)
verb - past participle of break. Adjective reduced to fragments; fragmented. ruptured; torn; fractured. not functioning properly; out of working order. Meteorology. (of sky cover) being more than half, but not totally,covered by clouds. changing direction abruptly: infringed or violated: A broken promise is a betrayal of trust. Sorry.....I couldn't resist it.
Ha thanks for the clarification. I just wondered if in this case it meant bent. As I had one straightened by motoliner back to perfect. I guess in this case it means fragmented.☺
i have ask many Ducati friend and shop. some said can some said cannot. because maybe off set problem...
Robin, I don't think they've changed the rotor offset between those 2 wheels. What city are you in? Your dealer should know if the offset is different. Is that wheel from a streetfighter or a 1199?
