My Shiny New Baby....
Discussion in 'Other Bikes' started by Lightning_650, Apr 3, 2015.
    TECHNICAL DETAILS
    ENGINE
    Design 2-cylinder, 4-stroke, spark-ignition engine, 75° V arrangement, liquid-cooled
    Displacement 1,301 cm³
    Bore 108 mm
    Stroke 71 mm
    Starting aid Electric starter
    Performance 118 kW (160 hp)
    Engine lubrication Forced oil lubrication with 3 rotor pumps
    Primary gear ratio 40:76
    Secondary gear ratio 17:42
    Cooling system Liquid cooling system, continuous circulation of cooling liquid with water pump
    Clutch PASC™ anti-hopping clutch/ hydraulically operated
    Ignition system Contactless, controlled, fully electronic ignition system with digital ignition timing adjustment
    CHASSIS
    Frame Tubular space frame made from chrome molybdenum steel, powder-coated
    Fork WP Semi-active Suspension USD Ø 48 mm
    Shock absorber WP Semi-active Suspension PDS Monoshock
    Suspension travel front 200 mm
    Suspension travel rear 200 mm
    Brake system front Twin-disc brake with radially mounted four-piston brake calipers
    Brake system rear Single-disc brake with two-piston brake caliper; fixed brake disc
    Brake discs - diameter front 320 mm
    Brake discs - diameter rear 267 mm
    Chain 5/8 x 5/16” X‑Ring
    Steering head angle 64°
    Wheel base 1,560±15 mm
    Ground clearance (unloaded) 220 mm
    Seat height (unloaded) 860/875 mm
    Total fuel tank capacity approx. 30 l
    Unleaded premium fuel (95 RON)
    Weight without fuel approx. 229 kg
  2. Nice. KTMs and Ducatis go very well together. Enjoy.
