My02 748r Battery Advice
Discussion in '748 / 916 / 996 / 998' started by Richieyzf, Feb 26, 2015.
  1. After a new battery for my 2002 748r, the Yuasa I had on there when I first bought her lasted years, when it finally gave up I bought a Bosch which tbh woz Shit! Only been on a year and it's fecked!!
    Any advice wha battery to buy? I've looked at the motobat ones and also lithium ion but am aware of lithium ion not being to great in cold weather.
  2. Yuasa.... tried dozens and still end up back with Yuasa. The Li On are getting better and a bit cheaper but unless you're hell bent on saving a kilo or two, then the traditionals still offer the best options
  3. I use Yuasa in my infrequently used cars and bikes and they usually cope well with infrequent use and last well.
  4. Yuasa all the way, still running the original battery on both my 13 year old 748 and 8 year old 1098. Can't get a better recommendation than that, can you?
  5. Richie, you may want to check that the charging system is working properly and check the condition of the connector from the alternator to the regulator (the one with 3 yellow wires behind the battery box), the pins inside the plug deteriorate and eventually will destroy the regulator by creating a high imbalanced ac supply load and lots of heat. Should be running 13.2 - 14.5v with the engine running, 13.6-14.2v on fast idle all measured across the battery posts. Also when you fit the new battery go for the same spec battery (yt12b-bs IIRC which is a sealed VRLA AGM battery) as the original one and after filling it put it on the charger overnight to properly condition it before fitting it. The Yuasa AGM batteries will easily last over 5 years if you treat them right and cost less than £50. Hugh's 13 years is impressive, I can only vouch for 7 years on mine but have seen many on here get fooled by claims on ebay for gel batteries (that are AGM) for £70 or more which last only a couple of years. Motobat is recommended often but they are the same spec as the VRLA AGM, heavily marketed (often wrongly) and much more expensive but don't seem to last as well. Like tyres your never know how good a battery is until they have worn out and most bike manufacturers fit Yuasa as OEM, there is a good reason why
  6. Another thumbs up for Yuasa, I too infrequently use my bike and don't put the battery on charge that often. I had reason to crank the bike over a lot yesterday as it wouldn't start due to a fouled plug, it coped really well despite it's lack of use and did not go flat.
  7. So I bought a Yuassa , fitted it all fine, used it a couple of times, put bike back in garage for 1-2 months tried to start her to go for MOT on Saturday and nothing, no fuel pump noise, no turn over, wouldn't bump start down hill & even tho battery woz completely dead, wouldnt do anything when connected to jump leads! I assume going with wha I've read there could be a relay problem??
  8. I have Motobat in all of my bikes now, i have tried Yuassa but they just dont like being left for long periods. I had a GPZ900r stood for about 8 months and typical Gpz it to about 15 minutes of turning over before it started, the motobat kept spinning it over.
  9. You might have a problem with the connection with the ignition switch which is on the frame near the headstock. I had this after a complete rebuild and it was just the switch making bad contact. Everything was dead and the bike would do nothing. Are you getting the oil light coming on and neutral?
  10. Yeah the oil light & the neutral light were both coming on?
  11. The headstock connection should be OK then although the ignition switch contact itself could be making no contact.
    Have you checked the solenoid low current feed where the battery is to see if it is making good contact, it's a single wire attached from the loom to the solenoid. If not then the solenoid will not work, that can cause similar symptoms.
    Your battery of course could be completely down and although have voltage it won't have enough amps to crank the motor. Do you have an alarm to drain the battery when it's standing.
  12. I'm gonna av a good look at her tonight, I do have an alarm fitted, it's a meta one? But even when I had it connect on jump leads to a car it still did nothing? Looking at exploded diagrams at the mo and there's a number of fuses tha could be the problem?
  13. Sorted her, she's running! It was the battery in the immobiliser had gone so flat it wouldn't let the engine start! Bypassed it and started 1st press.
