Could anyone save me some time and frustration by pointing me at the right place on the Navihalter site to buy an MTS-compatible mount for a Garmin Zumo 350? Thanks chaps.
Here's the links: Pre-2013 Multi: Navihalter Mount 2013-on: Navihalter Mount I have the pre-2013 on my Mutley and highly recommend it.
My only comment when fitting/using these brackets, is dont over tighten the bolts !! on mine, the previous owner had clearly done this, so that two of the captive nuts came away from the plate due to poor welds. Its a 'feature' of the design that the nuts are on the same side as the brackets, so the bolts are pulling the nuts away from the plate, not into it. I also use the pre 2013 bracket. Very pleased with it other than the above.
Hi Chris, they really work well, did you see mine when we was away? Great thing is they put the sat nav in your view, we need to get together at some point.
Yep, the Navihalter comes with everything you need to fit to the Mutley and, as long as your 660 comes with this mount (which bolts directly onto the Navihalter and should come with the 660), then that's all you need: Andy also provided a mod for tidying up all the wires you don't need as well which is worth a look: Click here
Pete - I don't think you were looking properly buddy, I had one fitted for the whole trip as well!! You probably got confused because I was still looking at the tank bag map all the time... PS Excellent purchase...
