Need Ducati 1199s Termignoni Race Exhaust Mounting Hardware Pack--
Discussion in 'Wanted' started by greg328, Dec 16, 2021.
  1. Hello UK Ducati people!
    Greg Giacona here, Austin TX USA. Needing to locate some Termignoni exhaust mounting parts.
    I've posted this on 3 US-based Ducati forums, but I thought I'd reach out to the UK in an effort to cast an even wider net.
    I recently bought a new but incomplete Termignoni Race exhaust set for my 2012 Ducati Panigale 1199S. I bought it from a vendor in Italy. He only sold me the 2 silencers.
    I then bought the Y-pipe and heat shields here in the USA. BUT—I need the hardware packet that contains all the brackets, screws, washers, spring clips, springs, etc..
    I would also like to get the exhaust valve motor delete plug, Racing ECU map key if possible, and possibly the race filter.
    I've reached out to my local Ducati dealer in Austin, they say they cannot help.
    I've reached out to Termignoni directly in Italy--waiting for a response.
    I'm hoping maybe somebody has some spares, or a part-out wrecked bike as a parts source.
    I have found the Ducati Performance installation PDF, which has a breakdown of all the parts and Ducati kit part number. I’ll attach it here.
    I’ll list the parts, by table number, the ones I need.
    I sincerely hope somebody can provide these mounting parts, because if I cannot find them, I cannot install my exhaust!
    Here is the list, from the parts table attached. (See below).
    I need part numbers:
    1. Exhaust valve motor connector cap
    2. Racing ECU enabling device—map key (if available)
    7. Heat guard retaining spacer—— X8
    8. Spring-— X2
    10. Silencer RH bracket
    11. Screw
    13. Silencer LH bracket
    14. Silencer front bracket
    15. Heat guard retaining screw.—X4
    16. Air filter (if available)
    17. Heat guard retaining clip —X4
    18. Heat guard retaining aramid washer—X8
    19. Rubber block—-X2
    In other words, I need EVERYTHING in the diagram except for the 2 silencers, the Y-pipe and seal, and the heat shields.
    Any help, for any of these parts, will be greatly appreciated!
  2. you should be able to order all ( apart from the Up map) online from a dealer
