Nemesis traction control system.
Discussion in 'Panigale' started by Brad3AB, Jan 14, 2014.
  1. Just a quick question, does anyone know if nemesis are doing the add on pod, so that on the 899 you can calibrate the traction control for different tires, but still have the normal DTC, it just gives you a bit more to play with??
  2. why not ring bikesportdevelopments and ask mick boesman he's the creator…..ish:wink:
