New Monster Owner Birmingham Uk
Discussion in 'Newbies Hangout' started by Craig Prosser, Aug 14, 2015.
  1. Hi
    I have just bought my first Ducati, a 2014 Monster 796 in black and just wanted to say hi.
    Also I do a lot of riding in town, does the 14T sprocket really help?
    Thanks
  2. morning.
  3. Heloo and welcome CP to the mad house :)
  4. Welcome :)
  5. Hi
    14T will help you deal with 'chugging' at low speed as you've already read no doubt. If it's your first time on a tract.. Ducati then it does take some getting used to in town.
  6. Welcome Dave :)
  7. Welcome.
    I'm probably in a slight minority but I prefer the std front sprocket .... at least I find that it suits my 750 best.
    I did lower the final gearing a while back and I did it by fitting a larger rear sprocket rather than a smaller front as this gives the chain a slightly easier time as well as avoiding any chain/swingarm clearance issues (though may require a longer chain depending on how far you go ...I got away with a 2 teeth increase with the original chain).
    I found that it made the engine much too "buzzy" at higher speeds.
    Tbh, I rather like the std, "long" gearing anyway as it suits the torquey character of the motor.
    It does take a little getting used to at first, but you get used to it.
    I find that, on slow turns around town, I often dip the clutch momentarily just before powering out of the corner, then feed it back in as I open the throttle.
    This avoids the "chug" and more specifically any transmission "snatch".
    In fact, lately I have been considering changing the gearing the other way, ie going even higher via a smaller rear sprocket, to give the motor a slightly more relaxed time at high cruising speeds ...but this possibly wouldn't be necessary on the bigger motors.
    Check out UKMOC for monster-specific stuff.
  8. Hi Craig and welcome to the forum :)
