New Ohlins SCU
Discussion in 'Multistrada' started by hottubbiker, Jun 21, 2013.
  1. I've noticed that Ohlins have released a new semi-active SCU mod to fit to non Skyhook multis. Anyone tried it? Do you know where I can get one from?
  2. P&H near Gatwick have sent out a mailer to all about this upgrade! Would be interesting to hear from any one who has fitted this.
  3. On second thoughts I wonder how this will affect the warranties? Having had one Ohlins ecu blow up and replaced, where does one stand if this one blows? You can just hear it already.....it blew because theres a problem with the shocks.....or even worse....your shocks are buggered because of the new ecu....Leaving yours truly stranded with a big bill....
    Ah perhaps I'm too pessimistic looking for danger behind every tree.
  4. Regarding warranty, as mentioned in a previous thread, suspension made by Ohlins, aftermarket ECU made by Ohlins. Work it out for yourself. Regarding what the ECU is like when fitted, check out the write up by Aircontechnical a while back.
