Hi So my ECU has fried and I need another one. New is the best part of £1000.00 Second hand way cheaper but would it work? If so how please? Cheers Bluey.
Depending on the age of your 749 I have a brand new virgin ECU that should be plug and play subject to an over write which Chris can do. It's an IAW 59M A2 WW010/0115_099 and I think Chris said it is good for pre 2004. Hope this helps. Andy
If someone could point me to the correct ECU on eBay or whatever I could purchase that and post it to you??
OK so I have a doner ECU coming and Chris is helping out too Result! Once I have the ECU back from Chris what is the procedure to make it work with my bike?
It's as easy as that. Ideally you should do a TPS reset but you will be ok without. If you have the red key you could code the ecu but I wouldn't bother. Don't forget to reattach the earth fly lead that goes under one of the ecu retaining bolts.
