Hi, Can anyone tell me the diameter of the rear axle on a 2018 monster 1200? I have a paddock stand with a 22mm pin will this fit? My wife picks up the bike in a weeks time so cannot measure it. Thanks
You might be able to fit a replacement pin or sleeve to convert it. https://www.demon-tweeks.com/uk/champion-single-sided-paddock-stand-sleeve-320020/
I made a nylon sleeve so my paddock stand fitted both small and large diameter. I have a length of nylon left over (outside diameter is correct) needs boring and parting off. How much of a rush are you in for it. I could send you mine to try and if it fits keep it. I can make up another one
Hi, no real hurry just wanted to have something ready for chain lube, tyre changing etc? That is a very generous off you have made and I appreciate it. Thank you
@firecat0_0 are you sorted now? I have a late 2016 standard 1200 monster and it is a 40m pin that fits. Not sure if any changes on later bikes but if you are still looking you are welcome to try my paddock stand with your bike if you fancy a trip to Woburn to try it. I couldn't find a cheap 40m pin anywhere and have ended up with another paddock stand instead as only £46 all brand new with delivery.
