1200 Enduro New Seat, Stupid Little Problem
Discussion in 'Multistrada' started by Edward Cunliffe, Aug 23, 2024.
  1. Just posting for any random thoughts, bought an Enduro comfort seat, trying to fit but it's not going far enough forward so I can get the two bolts on the sides in ... it's only adrift by 5 or 6 mm ... not sure if it's the bottom or top locating lugs at the front that's stopping it ... don't want to grind any bits off (yet) in case it needs to go back.
    Random thoughts appreciated.
  2. Seems it's the top two bolts that screw into the tank that are stopping it, at least I know where to do a bit of sympathetic material removal now.
  3. If it's similar to the mounting for the none enduro, there is a chrome bung that you can loosen up which is adjustable to lock the seat into position. Could be it needs to be rotated back a smidge.
  4. Ta, don't think I have one of those. I've taken the tank bolts out for now, seat goes on fine without them and there are two other chunky tabs holding it down.
