what sort of decibels are the 1199 pannis putting out ? can u say what circuit you were tested at also cheers all
Jimmy43, I had mine tested at brands hatch (lunch time) with standard cans 107db, I have been to Donington twice on 105db day and never had my bike tested at either. Hope this helps
yes cheers gizmo , thought they were loud was fancy taking it to one of the smaller French/Belgium tracks but didn't want to turn up and be turned away,
You'll be ok at donington if you don't trigger the fly by, there's one just as you come back round to the main straight and I think another near the curves (may need to check) i will say though that if you do trigger them your likely to get pulled in, doningtons system is wired through to the council and they like nothing more than throwing their weight about
Jimmy as damodici said above re noise at Donny, my 1199 never had any problems on the two track days I did there. AC
Morning all, don't suppose anybody has any idea what the 899's levels are with standard and Termi's, I did have a DB reader on my IPhone, however not convinced they are accurate.....wondered if anybody's tested ?
hi etherion was just looking at any track in euro, not specifically that company , really fancied doing a track a bit different to the usuall ones , like Cartagena,jerez,hockenhein. etc,,
Jimmy, don't worry. I ve done tracks all over the place and it has to be said i never ran into any trouble anywhere. All Marshals know by now that the static Always fails the 95 ones but allow you to go on and then moniter drive by. most of the mics are where everybody knows they are and will only go off when you should nail the bike at top revs. so nothing an earlier upshift can't solve... just relax and enjoy ...
From experience it's been the standard ones that have had noise issues. Kopes measured quieter than gizmos standard bike at brands. How that works I don't know.
