Went I and gave my workshop a bit of a clean and wheeled out the hyper so thought I'd just run it up. Nothing on the starter. Goes through the motions but nothing else. 11.7 it says it has in the battery but the issue is the neutral green light isn't lit up. It did start ok when last fired up but now the above. Ive checked the first set of fuses under the seat , next is the set under the LHS panel but I've also hooked up the charger just in case. And before someone asks............ yes, it's in neutral !!!
Clutch in , out I've even shaken it all about. For what ever reason it looks like the bike doesn't think its in neutral and pulling the clutch in makes no difference. I think 11.7 is ok but we'll see tonight after being on charge for 24 hours.
