848 Oberon Clutch Slave Cylinder
Discussion in '848 / 1098 / 1198' started by Festa, Jul 31, 2023.
  1. Anyone fitted this to there 848, is it a noticeable improvement and worth doing.
    Thanks
  2. Yes, i fitted one to my 848Evo, then my first 1098R and now to my second and current 1098R. Much better all round. I did also fit Brembo RCS master cylinders which also helped a lot. Well worth doing.
  3. As he said ^^, it makes the clutch lighter to operate at the lever which does wonders for the muscles and joints in your left hand ! Plus it doesn't detract from the operation of the clutch. Win win.
  4. I fitted one to my 1198SP, it solved the problem of the leaking original and improved the operation and feel of the otherwise standard slipper clutch.
    Tom.
  5. Is the part number CLU-0116 correct for a 2010 848?
    Cheers
    Dave
  6. i fitted one to an 899, as above, all good, but i noticed a change after 50 odd miles, i bled it 3 or 4 times (by taping lever to bar and undoing the nipple), no change so i put new washers on all round, master too which fixed it, a big improvement
  7. great but their anodizing leaves a lot to be desired....my red one has completely faded so id suggest an alloy colour one..
    As a matter of reference my 8 year old orange anodized chinese levers on my z1000 have not faded atall...
    #9 comfysofa, Mar 13, 2024
