Oberon clutch slave
Discussion in 'Technical Help' started by Stebinners, Jul 14, 2012.
  1. Just tried to fit anoberon on my ducati monster 1100 (2012) but it does not fit. On the clutch push rodthere is a pin tat prevents the oberon fitting.... Anyone encountered this?
  2. The Oberon should have had two pins with it if I remember correctly,
    But I think the second pin was only supposed to go in along side the first on on the old models.
  3. Apparently Ducati changed the design on the new 2012 models, Oberon have updated the design but sent me the old model!
  4. Doh, thats the Sh*ts.
    Is the new one backward compatible with the old models or do we have two versions of the Oberon now?
  5. Probably backward compatible. As there is a pin through the rod so the Oberon just needs to accommodate that.
