Hi, my original screen has the following numbers / letters 487.1039.1A DOT857 - AS6 - M25. this is on the edge of the screen, between the last two screw holes.
Looking at the pic on your other thread your screen isn't OE. The OE standards screen doesn't have the rubber edge and its a different profile
I think it's the DP large clear screen, I've got one on mine, but not at home so can't look at any numbers. Bike looks the same in profile though
Mine with the Ducati larger screen. obviously mine is smoked, but it looks the same shape. I'll pop into the shed today and see if there are any markings on it Do you get any cred for a composter as opossed to a wheelie bin?
Mine doesn't have the Altuglas but does have the CN Acrylic Doto626 stamped on it if that helps. Although on yours Acrylic looks like its spelt wrong. It's almost certainly a DP high screen or a knock off look-a-likee
Went out on my bike earlier & yes your screen has the same markings as mine, didn't check the spellings, but my screen new fron Snells - DP high screen, clear
