Anyone taken the OEM satnav wiring to a Navihalter? Is it easy to do and is there a step by step guide anywhere? AndyW?
Yeah I've wired my tomtom and run the wire up to the navihalter from the power socket , trimmed the wires and soldered mine in and heat shrunk over top of wires , very easy
All you need to know here http://www.motorcycleinfo.co.uk/index.cfm?fa=contentGeneric.psqlmptrfsppjcbe&pageId=1199858
Anybody got a source for a replacement OE connector? I'm thinking I might make up different leads for different purposes. (I know, I could do that with another connector after the OE connector, but more connectors means more chances for something to be not connected...
Moocow is correct with the details. Don't forget you will also need the correct crimp tools. I have the connectors and crimps, and can provide an extension lead if required. Personally I have a coaxial power connector in the fuse / relay area behind the left headlight. This allows for the satnav mount to be easily removed.
Google ultimate add ons. I have interchangeable leads for satnav and iphone, you can get usb and all sorts. Leads cost about a tenner after you have the base of £20
Eddie, contact John W of this parish and he'll sort you out with the connectors ready made up with wire pig tails (@John W )
Nothing. It's a factory fitted spare power feed which Ducati have installed on the bike for use in connecting up the Sat Nav etc.
So I see, in the post two above yours. I've already got crimping tools, so I'm quite happy to make up my own if I can get the bits. I haven't got the bike next to me, so I'm going by @AndyW's photos; is the 'accessory' side the receptacle or the tab from the CPC catalogue?
That looks quite useful, but my sat-nav takes a 12V feed, so I can wire the mount straight in. (Actually, it's so old, it's almost clockwork...)
