998 Ohlins Yokes....
Discussion in '748 / 916 / 996 / 998' started by pauliealdridge69, Sep 11, 2014.
  1. Picked up a set of 1098S ohlins yokes/bearings cheap on eBay...they're not here yet but I was wondering if anyone can confirm they'll fit my 998 and possibly the fork hole sizes they'll have as I'm now looking for some forks to go with them :)
    I rather have non radial due to having all the bits already and 4pad calipers but if they'll need radial then oh well lol
    Cheers for any help!
    Paul
  2. Top yoke should fit afaik not sure about bottom yoke and stem
  3. Got some 848/Monster 1100 radial calipers if you're interested.
  4. 1098 yokes slipped into my 748R frame non probs.
  5. should be 53mm top 56mm bottom same as ohlins for the 996r/998r
  6. probably ohlins from 749/999 should fit too (although dont know about length)
    I have a mint and unused pair of 4 pad brembo radial calipers from 999R if you need
  7. Cheers for the replies guys...ive not decided on forks yet but if i go radial ill give you both a shout^^
    Yokes arrive weds and are listed as 56/53 so fingers crossed....ive got the 998s so was just going to fit the earlier forks as i have all the correct 4 pad brembos and and lines etc to go with them....guessing i could keep all the same discs etc too hopefully?
  8. some ohlins forks (usually the OEM 996R 998R 1098 1198 etc) need 15mm offset discs, ohlins road and track forks for for the 996/998 use the standard 10mm offset
  9. yokes arrived and perfect...
    So they were bargain of the century!
    Now just need some forks!
  10. Just get your orig lower ones machined out for £20.
    much cheaper.
  11. I'd say you're wrong as these cost £47 delivered and I now have a set of Showa ones to sell with my forks :)
    Can anyone confirm the fork length of the ohlins from spindle center to fork top? Found a set but my bikes miles away from me as I'm working away...
    Cheers again for any help :)
  12. 725mm on a 999R Radial Ohlins, not compressed - i.e. wheel off the floor on an Abba Sky Lift... from spindle centre to top of main full diameter cap...
  13. better let me know a price then :)
  14. I feel a reverse bidding war about to happen here ;)
