Hi, Do these beasts consume? My dad had a Lotus Cortina that had an official consumption figure (ok a MK 1). My boss has a Cayenne that also has a consumption figure. Both were shocked when checking oil level, will I when I get my Multi? Thanks.
Multi engines are normally pretty good for oil consumption, my last 1200 I never had to top the oil between services and I covered over 10,000 miles.
Mine used quite a bit but that cud av been due to con rod through the casing lol, the present engine not used a drop in 1500 miles.
24k no top up needed between as above used all the coolant when the heads perforated, since changed uses nowt but BP ultimate!
