Oil Cooler M900/900ss Engine
Discussion in 'Technical Help' started by Duke em up, Mar 22, 2015.
  1. are there any upgrades or alternatives from the original?
    I need one for my project, its mounted in the higher position above the cylinder on my engine.
    Did the oil cooler change much after 94 before the model change?
    Thanks
  2. 999 oilcooler can be fitted.
    On my 900 Monster:
    On my SS project:
    Yorkie
  3. Do you get any benefits from this system?
  4. Not really sure to be honest, it is a larger capacity but I really just like the look.
    I'm looking for another two to fit to my next cafe racer project and the ST2 engine that will be fitted to my Monster.
    Yorkie
  5. Yep you get pretty girls drooling all over your bike.
  6. It does look smart, mine mounts above the lower cylinder so would sit higher.
  7. Just move it underneath, then it will sit where mine does.
    Yorkie
  8. 1) how does she know what the size of my knob is?
    2) I've gone blind and can't find the kleenex :(
    on a separate thought - I fitted a 1098 unit to my old SS.
  9. I used an ST4S cooler on my naked SSie for looks. It's curved and has large alloy ends that polish up well. Slighly smaller capacity and not straight swap, I had to get mounting brackets welded on.
