V4 Oil Leak Help
Discussion in 'Panigale' started by JimboV4, Oct 3, 2023.
  1. Hi all
    I have a 2018 B4 and have just had the sump and side cases re sealed using the correct three bond as I was getting quite bad oil leaks, however I am still getting oil leaking from the from right hand side behind the exhaust cable actuator thing
    I suspect it’s either related to oil cooler and pipes or the breather pipe
    does anyone have any previous experience with similar issue?
