1199 Oil Leak
Discussion in 'Panigale' started by Chris Hicks, May 2, 2016.
  1. Hi, I've noticed a oil leak from RHS of the engine. Only leaks under pressure and seams to be coming from the heat exchanger but can't be sure. Anybody else had leaks from here?
    I'm just out of warranty so wanted to see if it's a simple fix before I send it in to the dealer. Cheers
  2. Have you done a search for previous threads on this as I'm sure I've read a few posts regarding oil leaks. If you're literally just out of warranty I'm sure the dealer would be willing to help you out and not expect you to foot the whole bill though?
  3. Im sure there is an oil seal behind the heat exchanger, could be the culprit.
