Hi, Are oil leaks something i should just come to expect i will be seeing a lot of with the 1199? Cheers
Where is it Clint? I've had 4 Pani's and only had one valve cover leak which I caused myself from not torquing properly.
hi, it seems to be located round the oil filter access. However, that could just be where the oil is running down too. The bike is in the garage under warranty from Tuesday anyhow. I was just hoping that oil leaks are not a common thing for Panis.....this is my first one. Cheers
