Anyone have any tips or tricks to replacing the oil level glass without removing the cases? I read on here somewhere that the glass is pushed in from the outside? so be handy if it can be extracted without removing anything.
this may help for starters:- https://www.ducatiforum.co.uk/threads/oil-timing-inspection-window-how-do-i-remove.42460/ https://www.ducati.ms/threads/need-...il-viewing-glass-on-clutch-side-casing.63595/
As its getting replaced, I should be able to pull it out with drilling and possibly screwing a self tapper to pull on?, If it breaks its not a problem.
