oil temp gauge wiring
Discussion in 'Supersport (1974-2007)' started by Sev, May 8, 2013.
  1. Just a quickie,
    Oil temp gauge, three blade connectors on the back, am I right in thinking:
    + VE
    Earth
    com = Signal from bobbin sensor on the oil screen pickup.
    what connector is on the bottom, is it a female spade connector with a rubber boot? and how thick is the wire?
    surely 18 - 20 awg should be more than ample?
    thanks in advance.
  2. 18 - 20 awg will do :upyeah:
  3. Imola, thanks for the confirmation :)
    Well, here it is, I remade the loom from the Elliot electronic rev counter and the original veglia temp gauge. The earths all go to the comon earth on the frame and the comms wires are all continuous. The pulse take off for the tacho has been spliced neatly into the coil wiring and I also took the opportunity to put a final loom section for a speedometer and ample wiring for the wheel speed sensor.
  4. Neat work Sev:upyeah:
