Hello i have travelled to croatia from yorkshire what a blast,however the oil warning light is on having filled with the correct oil the light is still on is this any thing to be worried about as i have a long ride home regards Mitch
What bike have you got? Check the oil sensor/sender that is plugged into the crankcase on the right-hand side - is it showing signs of leaking? This part often gives out false positives for the oil light, it just needs replacing if it has gone faulty. Leaking oil is a good sign of this.
What bike are you on,the St or 998 916 and others had a very unreliable oil pressure switch, this part is the same as General Motors part,but GM part is about 3 euro
Thanks its still under warranty with ducati in shipley any way its all sorted now. thanks for the link.
