One Head Light.
Discussion in 'Other Bikes' started by Not Carl Fogarty, Jan 17, 2016.
  1. I'm thinking of putting an old (R6) race bike back on the road.
    I want to keep it looking as race orientated as possible. I did see an R6 years ago with one stock head light and the other side of the fairing blocked off. This would be ideal, I could have a number board background on one side, maybe....
    Is this legal (one headlight) or is it day time mot only?
    does it meaning altering the blub position/ beam pattern not sure how adjustable they are.
    Any advice appreciated, I don't want to fit some ugly light. I rather keep to stock profiles etc. If I have to, I will run stock head lights and fairing.
    It's such a shame to ditch the race parts (Harris upper fairing brackets) for stock :(
    I hope the top yoke GPR steering damper will not effect where the ignition goes, grrrrr.
    #1 Not Carl Fogarty, Jan 17, 2016
  2. Having just one light isn't illegal, two of my bikes only have one light as do loads of others.
    You could get a light with both high and dip beams in it but even if you only have a dipped beam it should still be OK, I don't think it's a legal requirement to have a full beam...?
  3. I did see this on a R6 outside M&Ps years ago. Must have been a race fairing with one hole cut out for one standard head lamp, that's the plan anyway. I will keep the single seat unit and fit an led brake light and mini indicators, flush ones at the front.
    I think it will suit what I have planned as long as I can get a normal MOT, non of this day time business - if they still do that.
  4. If you look at my avatar you will see my 748 with a single 3 1/2" headlight. I fitted that with a HID that dips. Passes MOT and the light is as good as the standard set up
