Outhouse Roof - Forum Expertise/knowledge Welcomed
Discussion in 'Lounge' started by ibgarrow, Oct 28, 2022.
  1. I have a stone-built outhouse, used to be the outdoor toilet, ex-coalhouse, in which I keep my e-mountain bike. Unheated, concrete floor, pre dpc days.
    The roof is slate, single pitch, like a lean-to, but it doesn’t “lean to” anything.
    Some of the slates need refixing, the ‘ridge’ capping too, and there are visible gaps (no underlay, felt or membrane.)
    Roof area is about 8 feet square
    I’d like to remove the slates, replace what timbers need doing, and relay the slates.
    Q: should I lay a membrane under the slate battens?
    I intend to fix some Kingspan insulation between the roof joists.
    Q: do I need to lay a board deck too?
    All advice welcomed.
    Thanks in advance.
  2. Strip it off keep the ridge tiles safe and keep and slates that are in a good condition- when you tap them with a chisel they should ‘ring’- duff ones don’t
    if the timber is in good nick leave it in place
    Use a breathable ‘felt’ membrane and re batten with new tantalised battens then re-slate using reclaimed slate for colour and size if needed
    Re bedding the ridge as you finish.
    New guttering and down pipe?
    A small scaffold lift would be very helpful
  3. How are you stripping the slates. The old method was to use a ripper, but now they use a slate hammer around the nail.
  4. Thanks for this. I’m glad I don’t need to have a ‘deck’ too.
    The ‘ridge’ is currently just a cement strip along the top of the wall where the slates stop. I have some ridge tiles that could form a ridge…
    Hopefully the underlying joists will be in good nick.
  5. I planned to rip them but will see what the nails look like once I start.
