749 Overfuels At Approx 5k Rpm Power Commander
Discussion in '749 / 999' started by DeanF, Jul 12, 2014.
  1. Good afternoon all.
    My 749s overfuels at approx 5k when revving at a standstill, Puff of Black Smoke & the tell tale slight MisFire due to this....
    now i dont know what map it is running but on the road it pulls well with little hesitation apart from really low speed crawling.... Thinking logically they are a Forced induction system so stood still they will be much richer due to the lack of forced cool air....
    So.... Is this normalish ?
    And im thinking of ging for a custom map..... Anyone have any mapper reccomendations in the Stoke / Staffordshire area ?
    Cheers :upyeah:
    Dean
  2. Why have a powercommader. And use a generic map. Your right in getting a custom map. Make sure it each cylinder mapped separately.
  3. Looks like a v good setup there with plenty of knowledge & info. :upyeah:
    Cheers
  4. Riderz up 'anley way duck..... lol they set my map up when i had a PC3 on and they were very knowledgeable and helpful.... D&K do it but TBH past experience with them i wouldnt bother.
  5. Why not plug your PC3 in to a laptop and find out what map. You are able to adjust via the software.
    Or unplug the power commander and try it without
  6. Booked in with Bikerz & also plan to load the software onto my lappie to have a play, im certain my Tps needs a reset !
    Cheers
    Dean
  7. Don't try to TPS reset using the feature in PCIII you will find your bike won't start.
    To TPS reset search JPDiag on the forum.
  8. Lol yeah i meant Bikerz, they used to be called Riderz when they first started up
