1299 Paddock Stand Pins
Discussion in 'Panigale' started by Squadra Corse, Jun 23, 2018.
  1. So a weekend question for you forumites as the company is closed..
    Does anyone know if the replacement pins that R&G sell fit the Ducati Performance single sided stand? I'm wanting to continue to use the stand after fitting some axle protection slider thingies that reduce the original ~41mm diameter of the axle tube hole on my 1299 down to about 30mm. R&G do a 28.6mm pin.
    Thanks
    #1 Squadra Corse, Jun 23, 2018
  2. I got a 50mm nylon tube (ebay) and a guy at work with a lathe turned it to 41 and drilled a 25mm hole in it. So now my stands works on my 916 and my 1299. One stand = more room. :)
  3. i had the ducati 848 paddock stand and the R&G pin for my multi fitted it no problem at all. i did post this info a while ago
  4. Never saw your post before on this. Is the 848 stand the same as the most recent stands as far as the part of the pin that's inserted inside?
