1200 R Paddock Stands
Discussion in 'Monster' started by flatstick959, Aug 23, 2018.
  1. can anyone recommend a decent paddock stand for monster 1200R
    I use Harris on my panigale but that’s double sided swingarm
    Thanks
  2. Harris do single siders too.
  3. You could put some Axle bobbins on the 1200R and still use your current stand?
    You would be a bit limited for what it can be used for though...
  4. My mate did that with his piles peak. Can’t take the wheel out though
    I’ll have a look at Harris again as I’ve always used them
    Do their Front stands fit the ohlins forks ok or do you need a pin or something?
    Thabsk
  5. I went for a 1Jac - British made. Can lift the whole bike off the ground in a single movement. mine was used to make the first 1200R fitting kit - highly recommended http://www.1jac.com/
  6. Thanks I’ve got an ABBA stand already but use paddock stands at Trackdays and for daily mainatnance and cleaning etc the lifts are a faff I just use them for bigger jobs
  7. Anyone tried a constand head lift?
    They any good?
  8. Thanks I might give them a go
  9. I have the same stand. Can't fault it tbh.
  10. Really good, aren't they? I think I only paid about £65 for mine - they seem to have put the price up a bit, but even so, the construction and quality is excellent.
  11. Really good, aren't they? I think I only paid about £65 for mine - they seem to have put the price up a bit, but even so, the construction and quality is excellent.
