Does anybody know what the paint code is for the Grey Marchesini wheels? Also, the metallic grey used on the Ducati's frame? Many thanks.
RS Motorbike Paint Colours - Motorcycle paint, bike paint, Kawasaki Honda Yamaha These guys are pretty helpful and if their search system doesn't turn in what you want they will provide the paint codes by email, so you could go else where after getting the info you need.
RS supply their paint mostly as water based paint if you want it in two pack then you want either Grigio Metallic which as a PPG code is PPG 0011 or Grigio Steel Metallic which is PPG 223 647. See below if you want the earlier dark silvers.
