1199 Panigale And Abba Skylift
Discussion in 'Panigale' started by West Cork Paul, Aug 17, 2023.
  1. Does anyone use an Abba Skylift with a Pani? How on earth do you get the lift low enough to connect to the swingarm pivot bolt? I’m struggling.
  2. Remove the arm that attaches to the rear wheel axle. The jig then can drop fully. Once in place pump it slightly until you can refit the arm and you’re done.
  3. The other option is leave bike on paddock stand and raise the lift - depending on where my bike is resting I use both approaches.
  4. I had to use this method on the 749 I had.
  5. Thank you all :upyeah:
