899 Panigale Integrated Tail Light
Discussion in 'Panigale' started by Red899, Oct 14, 2016.
  1. Make sure they are E marked as otherwise you might fail mot.
    Also male sure that the indicators are visible to other drivers as the lats thing you want is that the car drivers don't see it , you know what will happen.
    Most of them are hard to see while the brake lights are on at the same time.
  2. In the UK you can use this but need to retain the original indicators.
    Sent from my SM-G920F using Tapatalk
  3. I put one on my 1199 pan and it was beautiful. Pain in the arse stripping the seat unit but well worth the effort. Tidies the arse up lovely. No wiring, just plug and play.
  4. I would say that somewhat defeats the point of it!
    I have also heard these are not legal in the U.K., but just rumours.... I am not sure why it isn't legal.
  5. i bought one for one of my 675's but never got round to fitting it, ive heard the same too (ish) but i have a very lenient mot chap :)
    thanks all
  6. The UK requires the indicators to have a separation distance between them. I believe that's also the reason aftermarket indicator come in different lengths, so you can achieve the minimum distance.
  7. Just looked it's 180mm minimum between indicators
