1199 Panigale Running Temperature
Discussion in 'Panigale' started by Niven770, Feb 20, 2015.
  1. When on track in Almeria my S1k runs at about 90 deg C, this was with an ambient temp of around 25 deg C. The Panigale was running at 100 deg C with an ambient temp of around 18 deg C.
    Does anyone have any experience with Panigale running temperatures on track ? I'm trying to ascertain if there is a possible problem or not.
    Cheers
    Davy
  2. At Mugello mine was running ~92-95, with ambient temp ~20
  3. Thanks
    Maybe mine is running a bit hot, thats what I was thinking. Not really concerned about the 100deg it's just that if ambient is higher it might become a problem.
    Cheers
    Davy
  4. Open the throttle a little wider and increase air velocity through the radiators ;)
  5. Open the throttle a little wider and increase air velocity through the radiators ;)
  6. Aye any faster and i'll fall off.....but if you have any tips for going faster around Almeria i'm willing to listen.
  7. I've no tips, captain slow's me.
