Pantah street tracker
Discussion in 'Builds & Projects' started by desmohog, Aug 7, 2012.
  1. Building a street tracker. This will be a day time MOT, bare bones build, using an Alazzurra frame, 750 Paso front end and engine and an assortment of junk I have gathered over the years.
    This should be a quick build but I have promised the wife a loft conversion first.....so updates will stall for a while!
  2. Very nice, having seen your other projects I can't wait to see the finished result ;-)
  3. Ouch! I take it you'll be using the 750 crank as well? When I converted my 500 Pantah to 650 I had to bore the crankcase mouths as well. The only issue I had was clutch slip!
  4. The 650 clutch is a larger diameter than the early 500 so should be ok. I ended up with heavy springs with perfect plates and it was ok. I always thought that Weber was a sod to set up!
