Penetrating Fluid. Which Is The Best Of The Best
Discussion in 'Clothing, Gadgets & Equipment' started by Davyd, Apr 30, 2023.
  1. I’ve a 94 916 which has been laid up for over 20 years, so I’m assuming a few stuck bolts. I’m in no hurry to sort it out but I suppose a few squirts of some stuff won’t do it any harm in the long run. what do you guys recommend..
  2. Plus Gas
    • Agree Agree x 6
  3. Wurth creep oil, worked on the notorious stuck swing arm bolt or plusgas also good.
  4. ^^ both good choices. Kroil’s another…
  5. Plusgas or gas axe, it it's liquid - it's not tight!
  6. Plus gas for small jobs, soaking in diesel for big ones
  7. Some use the freeze spray along with penetrating oil if you’re in a pinch for time.
  8. Looks like plus gas is coming out as favourite. As I said I won’t be doing anything with the bike for a good while so in the meantime I’ll give all the fasteners a blast with the gas from time to time and hopefully it’ll help when the time comes. Thanks for the suggestions/advice.
  9. Normfest super crack ultra is good.
  10. oxy acetylene or mapp gas
  11. Plus Gas worked on my 3 seized bolts holding exhaust Y piece together. After 7 years of heat and grit from rear tire they came out very easily. Just sprayed and left over night. Excellent stuff:upyeah:
  12. I've had good results with Plus gas. That's on an engine strip down. including very rotten looking exhaust bolts. Worked well on a Monster rear wheel nut that has got a little corrosion. Give it time to soak, and whatever you use heat always helps if you can use it.
  13.
  14. All of the sprays mentioned so far will do the job well enough ,
    but it's certainly an expensive way to buy paraffin ..... plus a small amount of solvent ,
    and of course , "the secret ingredient" ...... the wonderful fragrance ......:D
    But don't take my word for it ..... " Only A Fool Would Say That "
    ..... :cool:
    If a product is offered for sale in the USA , all of the ingredients have to be listed on Federal websites ,
    which are available to the public .
    #16 oldtech, May 3, 2023
  15. ‘Penetrating fluid’
    hehe
  16. Parafin = wonderful stuff. Cheap too. Ive got a few litres of it. I filter it with an old coffee paper filter thing afterwards and re-use it. Dont tell wifey where coffee perculator went. It broke and I threw it out. Best chain cleaner there is.
  17. There is a bit more to it than that.
  18. super crack ultra penetrating fluid
    Fnarr fnarr
