999 Place Your Bets ....
Discussion in '749 / 999' started by Bluehawk, Mar 21, 2015.
  1. Had the sprag clutch replaced at the end of last season and a service with new plugs.
    I had started it up when I got it delivered back, but it was running rough, sounded like 1 cylinder. It then couldn't start it after that.
    Sooooo. Any guesses? Coil pack, dirt in the fuel lines or further suggestions.
    Bike will be getting picked up next week, so we'll know what it is then..
    Correct diagnosis gets a 'like' from me....:upyeah:
    Dyno run for the start of the season....I might not publish the final figures.....
    #1 Bluehawk, Mar 21, 2015
  2. fuel pump.
  3. Faulty plug.
  4. Not really sufficient info for a diagnosis mate.
    You say the bike won't start now. Was it defo running on one cylinder when it did run, or just sounded rough?
    Have you got a good battery, are you using the cold start lever, have you possibly flooded the engine attempting to start it?
    More info needed!
  5. New battery, don't think it has anything to do with cold start lever. Faulty plug .....could be...
  6. Any dashboard MILs ?
  7. Dash is all clear.
    Did find out if you hold down RHS dash button at start up, it puts the dash in track mode....but you all knew that...
  8. I am going with faulty plug too, possibly fouled up.
