1200 Possible New Owner Pannier Question.
Discussion in 'Multistrada' started by Darren Seaborn, Nov 2, 2014.
  1. Hi Gents,
    Thinking of getting a Multistrada soon , and wondered how easy/expensive it it to get OEM panniers & top box if the bike I eventually buy doesn't have them as std?
    Thanks
    Darren
  2. Are you buying new or second hand Dave?
  3. More than likely used!!
    New is a bit out of my reach.
    D
  4. They come up on here and ebay fairly often but are never cheap. Expect to pay about £300 for a topbox and a similar amount for the panniers.
  5. You can buy them also off ducati
  6. Darren, when you buy do not forget the support brackets that bolt onto the pillion foot rest hangers.
  7. Hello and welcome to the forum :)
  8. Thanks for your responses guys n girls .
    I'll be back with more stoopid questions as I get closer to buyin one!
    Cheers
    D
  9. If you are to spend about an extra £500-600 on panniers and top box I reckon buy one with these already and it will cost less ,at least you can haggle down the cost of the bike with these already fitted.
  10. Just be careful if buying used. You need a long warranty to fall back on when things go wrong.
    This one looks the part, but see here and here for details of its history.
    In the time I had it, I had the following replaced under warranty, then finally decided to get rid when I got a bill of £1300 for a failed main engine bearing:
    Radiator
    Right-hand switchgear
    Left-hand switchgear
    Sidestand switch
    Clutch-fluid reservoir
    Front brake-fluid reservoir
    Exhaust compensator (section incorporating exhaust valve)
    Rear brake caliper
    Tail-light bracket
    Water pump cover
    Clutch-side crankcase cover
    Generator cover
    Instrument panel
    Steering lock mechanism
  11. With the announcement of the new multistrada I would guess the prices of previously enjoyed ones to fall. Being the case if your budget allows,go for a 2013 updated model,as this does address quite a few of the issues of the older generation.
