749 Power Commander
Discussion in '749 / 999' started by mattyboy 38, Aug 15, 2015.
  1. Hi help needed I have just bought a termi system for my 749 I've also been offered cheap a power commander would this help and does any one know how they work
    Any info would be appeciated
  2. I ran my 05 999 with termi asymetric and std ecu (as I bought it) for 5 years with no problems. You can set up PC3 from laptop via PC/website for various maps or have custom map written. I have PC3 on my SS with map for DP cans/KN and it improves bottom end, I have the accelerator pump simulator option live to about 35%. Have a look at their website. Other alternatives are ecu reflash to DP map or ecu custom remap.
  3. i dont have power commander with my full termi , came like this so i presume it was already set up, runs with no problems at all.
  4. If its about £100 you will always get your money back on it. It should come with a couple of leads, 1 that connects to lappy usb which you will need. Other accesories are cd which is not really needed as you can download free from DJ website.
  5. Well I've bought it 90 quid new in box with all cd and leads yeh baby
  6. I had a Power Commander fitted to my 999s with Leo Vince full system but wasn't happy with it. Got the bike to Louigi Moto / CJS and had the ECU re-mapped (and PC removed). Chalk and cheese. More expensive than a cheap PC but worth it in my book.
  7. Does any one know of a good rolling road specialist in or around Manchester that could set up or remap
  8. Why were you not happy with it
  9. There's a couple of bits to the answer.
    When I bought the bike it had the asymmetric pipe and Termi fitted whith the appropriate ECU. It was okay but I thought a bit 'coarse' or rough. I had the chance to buy a Leo Vince full system at a very good price which got fitted. With the 'asymmetric' ECU fitted the response was rubbish with loads of flat spots. In an attempt to smooth this out I had a PC fitted and set-up on a dyno by a genuinely pukka outfit. While the response was loads better there was still a flat spot just off closed throttle which made riding the bike unpleasant - the bike almost had to be coaxed passed this point. I lived with it because the response and performance further up the rev range was good.
    I had spoken to Rich at Louigi Moto a number of times in the past about the subject and eventually one day I decided see what could be done. He told me Chris at CJS (who shares workshop space with him) could re-programme the original ECU and do away with the Power Commander. I gave it a go. I was chuffed. The already strong top end was unchanged but the flat spot off-idle was gone and the throttle response generally was better. The PC was now redundant and removed.
    Ok, so arguably the original set-up might not have been done as well as it could have - they were based in Kent and I'm in Gloucestershire so a bit of a hassle to go back. CJS are kind of 'down the road' and I liked the elegance of the re-map.
    This is obviously just my experience. It obviously all cost me extra but I'm more than happy with the end result.
