1200 DVT Power Connection Hub
Discussion in 'Multistrada' started by JohnoDuc, May 23, 2021.
  1. As I’m still quite new to the Multistrada I’m trying to work out what power hub I can use from the connection at the front of the bike. I have seen the genuine ones from Ducati but seem a bit pricey. Gavi do one but not sure if it has the correct connector.
  2. I installed a denali powerhub2 under the back seat zone. For ease of wiring & potential fuse changes. Though I had my gps connected to the pre-installed front power connector. Because that is what it's designed for. Another one is for the fog-lights but both seem to require the tank to be removed.
    #2 GunZenBomZ, May 23, 2021
  3. I've never heard of anyone having to remove the tank to access the GPS feed, its just under the left had black Ducati trim, by the fuel sender
  4. I think it might of been for my foghorn relay install then @BabyD
