Power For Satnav
Discussion in 'Hypermotard' started by panigale66, Aug 25, 2017.
  1. Can anybody tell me where the power cable is to hook up my satnav to the hyperstrada ?
  2. 2 connectors behind the headlight. Both switched live but one needs to be activated by the dealer as it's for heated grips. The other is ready to go.
    *i got this info from here*
  3. I've already got the heated grips
  4. Well then you need to use the other connector unless the heated grips are plugged in to the wrong one :)
  5. Right find it Next question where are you meant to hide the wires and the volt transformer on a Garmin satnav?
  6. Where are you mounting it?
  7. Tried a satnav once.. pages kept blowing about in the wind so just use road signs now
  8. Thats a bit of a personal question !!!
  9. On the handlebar clamp
