Pragmasis Anti Pinch Super Pin for sale. Only had it for a few weeks, then sadly sold my Multi V4S, so no longer required. It's the special version, designed to fit through the rear wheel spindle/axle of the Multistrada V4S, Multi V2 and the 899 Panigale. It may fit other models that use the double sided rear 'arm and the same axle. The Super Pin has tungsten carbide rods inserted at either end of a hardened steel bar. Currently £120 from Pragmasis. I'd been using it with a 19mm Protector chain from Pragmasis, one of their ground anchors and a Squire SS65CS CEN 6 closed shackle padlock (Pragmasis recommend the SS65CS Stronghold lock for this particular Pin). The advantage of the 'through the axle' approach is that it's very secure and easy to use (no threading heavy chains through the wheels). See pix of the Super Pin in use (note that the lock and chain aren't included in the sale). £85 posted to a UK address, or £80 if you want to collect it from Beverley in East Yorks.
