1200 DVT Preload Suspension Settings
Discussion in 'Multistrada' started by Sam1199, May 5, 2019.
  1. What are the default preload settings for Sport and touring? Mine is set at 24 on both.
    Which is firmer 24 or 1?
    I’ve read the manual and am none the wiser.
    Suspension seems ok for 1 up no luggage but but a bit soggy for 2 up and full luggage.
    Yes I changed the mode from one to two up+luggage.
  2. Set it all at 1 and see what happens...
  3. 24 is hardest
    There is also a reset function - to reset to standard factory settings.
    From memory Touring was 12 and Sport 16 - single rider.
    But really suggest you start at Factory settings.
    Remember to set touring Throttle back to fastest mode..
