Primary Gear Puller
Discussion in 'Wanted' started by Pauldonjuan, Aug 5, 2024.
  1. Does anyone happen to have a primary gear puller for our Ducati engines. I want it for a 900 SS engine but I know it’s the same for a huge array of Duc engines.
    If you have one that you’re prepared to sell please drop me a PM.
    Thanks.
  2. There are ones on eBay if you can't get one from anywhere else.
  3. It’s well worth an ask for a used one before I buy a new one :upyeah:
  4. Best to try to borrow one off a friendly soul on here. Unless you intend to rebuild lots of engines. :upyeah:
  5. I might just try the asking to borrow if I haven’t managed to pick up a pre-enjoyed one by the time I need it, will be in the next couple of months. :upyeah:
  6. Does anyone have one they will sell or can I borrow one for beer tokens :)
  7. I was too right to buy the special one. Tried my existing 2 leg puller and had no luck. I'm the end I bought a beefier 2 leg puller.
    Sealey Ak46150 Twin Leg Puller Bar Type 150 X 150Mm https://amzn.eu/d/bPBz6h3
    This one just fits and worked a treat. Just leave the loosened nut on the shaft as they go with a big bang.
  8. Also a good technique is to add tension with the puller and then a firm whack with a plastic mallet to get it to go. :upyeah:
  9. I will try that puller you suggest :upyeah:
    I have tried my 3 jaw on it with the usual techniques, boiling water, sharp tap etc but it’s obviously not up to the job, I broke my trusty old 2 jaw on another job a while ago, that used to get these primary gears off.
    Cheers.
  10. If you join DOCGB they have a tool hire facility :upyeah:
  11. Hi Paul
    I’ve got a primary gear puller if you want to borrow one, you’ll have to swim over to Blackpool to get it though, send me a message if you want to borrow it
    I got it from gb motor cycle products on flea bay and it worked a treat on 900ss after other pullers either failed or were coming close to seriously damaged either the engine or myself. It’s currently resting in the garage awaiting a challenge
    Fergus
  12. I've done 3 or 4 now with an old 2 leg puller I inherited from my father.
    Put some tension on with the puller and add a little heat carefully to the gear.
    Add a little more tension then give the end of the puller bolt a sharp tap with a hammer.
    The OP obviously doesn't need the above advise, but if anyone who's not done one before is reading this and thinking of having a go, the most important thing to take away from this thread is:
    It's good practice anyway when doing something like this, but the amount of force needed to get these things off really can make them fly off.
  13. Many thanks to bumpstart, sorted :upyeah:
